이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place the TV face down on a flat smooth surface as to not scratch the screen.
Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
Using your hands, gently lift and remove the back case of the television.
Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
Remove the green and gray power connector from the side of the buttons panel at the top of the television.
Remove the green/gray to orange/gray connector from the center of the circuit board.
Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
다른 2명이 해당 안내서를 완성하였습니다.
