이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Place the TV face down on a flat smooth surface as to not scratch the screen.
Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
Remove the two 6mm Phillips screws.
Pull the board toward you, giving you access to the power button.
거의 끝나갑니다!
결론
