주요 콘텐츠로 건너뛰기
Sharp EL-520X Loose Circuit Board Wire Fix
필요한 것
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: 1 단계, 이미지 1/1
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: 2 단계, 이미지 1/2 Sharp EL-520X Loose Circuit Board Wire Fix: 2 단계, 이미지 2/2
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: 3 단계, 이미지 1/1
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: 4 단계, 이미지 1/1
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: 5 단계, 이미지 1/1
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: 6 단계, 이미지 1/1
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: 7 단계, 이미지 1/3 Sharp EL-520X Loose Circuit Board Wire Fix: 7 단계, 이미지 2/3 Sharp EL-520X Loose Circuit Board Wire Fix: 7 단계, 이미지 3/3
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Mohamad Mohamad
회원 가입일: 01/18/21
436 평판
안내서 3개 작성하였습니다
York University, Team M-6, Allen Summer 2023 York University, Team M-6, Allen Summer 2023 회원
YORK-ALLEN-SU23SMG6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 29
전체 시간: 360
