주요 콘텐츠로 건너뛰기
Sharp EL-546XT Battery Replacement
필요한 것
  1. Sharp EL-546XT Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sharp EL-546XT Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the calculator on a clean workspace with the back facing up.
  2. Sharp EL-546XT Battery Replacement: 2 단계, 이미지 3개 중 1개 Sharp EL-546XT Battery Replacement: 2 단계, 이미지 3개 중 2개 Sharp EL-546XT Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. Sharp EL-546XT Battery Replacement: 3 단계, 이미지 3개 중 1개 Sharp EL-546XT Battery Replacement: 3 단계, 이미지 3개 중 2개 Sharp EL-546XT Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. Sharp EL-546XT Battery Replacement: 4 단계, 이미지 2개 중 1개 Sharp EL-546XT Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the battery door from the calculator.
  5. Sharp EL-546XT Battery Replacement: 5 단계, 이미지 3개 중 1개 Sharp EL-546XT Battery Replacement: 5 단계, 이미지 3개 중 2개 Sharp EL-546XT Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. Sharp EL-546XT Battery Replacement: 6 단계, 이미지 3개 중 1개 Sharp EL-546XT Battery Replacement: 6 단계, 이미지 3개 중 2개 Sharp EL-546XT Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. Sharp EL-546XT Battery Replacement: 7 단계, 이미지 2개 중 1개 Sharp EL-546XT Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. Sharp EL-546XT Battery Replacement: 8 단계, 이미지 3개 중 1개 Sharp EL-546XT Battery Replacement: 8 단계, 이미지 3개 중 2개 Sharp EL-546XT Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Attach the screws back to the battery door.
  9. Sharp EL-546XT Battery Replacement: 9 단계, 이미지 3개 중 1개 Sharp EL-546XT Battery Replacement: 9 단계, 이미지 3개 중 2개 Sharp EL-546XT Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mithunan Sivagnanam
회원 가입일: 05/22/23
196 평판
안내서 1개를 작성함
York University, Team A-11, Allen Summer 2023 York University, Team A-11, Allen Summer 2023 회원
YORK-ALLEN-SU23SAG11
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 1,086
