소개
I am not responsible for anything in this article.
  1. Remove - Back,microSD,battery,sim Remove black rubber screw covers on back of display. Remove 000 phillips screws (4) from top of display.
    • Remove - Back,microSD,battery,sim
    • Remove black rubber screw covers on back of display.
    • Remove 000 phillips screws (4) from top of display.
  2. Remove 3 small silver screws from battery area. Remove 2 Torx t-7's by MicroSD slot.
    • Remove 3 small silver screws from battery area.
    • Remove 2 Torx t-7's by MicroSD slot.
    • After screws are removed you can detach screen.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove 4 additional 000 phillips screws from display. Using some heat,spudger,frce pry away the broken display from the frame. Use extreme caution the actual display is very fragile.
    • Remove 4 additional 000 phillips screws from display.
    • Using some heat,spudger,frce pry away the broken display from the frame.
    • Use extreme caution the actual display is very fragile.
  5. Remove connector for digitizer replace connector with new digitizer and rebuild. replace connector with new digitizer and rebuild.
    • Remove connector for digitizer
    • replace connector with new digitizer and rebuild.
  6. Reconnect to main motherboard. Reconnect to main motherboard. Reconnect to main motherboard.
    • Reconnect to main motherboard.
  7. reassemble. Enjoy the new display Enjoy the new display
    • reassemble.
    • Enjoy the new display
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jckoniecki
회원 가입일: 2010년 11월 08일
51 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 2
전체 시간: 3,248
