주요 콘텐츠로 건너뛰기
Sharp Microwave Door Switch Replacement
필요한 것
  1. Sharp Microwave Door Switch Replacement, Door Switch: 1 단계, 이미지 2개 중 1개 Sharp Microwave Door Switch Replacement, Door Switch: 1 단계, 이미지 2개 중 2개
    • Sharp microwave running with door open
    • Problem with the hardware interlock switches triggered by the door latch
    • Sharp model R-248BS
    • Unplug the microwave before you begin disassembly.
  2. Sharp Microwave Door Switch Replacement, Remove screws: 2 단계, 이미지 3개 중 1개 Sharp Microwave Door Switch Replacement, Remove screws: 2 단계, 이미지 3개 중 2개 Sharp Microwave Door Switch Replacement, Remove screws: 2 단계, 이미지 3개 중 3개
    • Side screw
    • ...and 4 screws in the back
    • Star screws need T15X4 or equivalent. A flathead can be used in a pinch.
    • Remove the screws
  3. Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): 3 단계, 이미지 3개 중 1개 Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): 3 단계, 이미지 3개 중 2개 Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): 3 단계, 이미지 3개 중 3개
    • Remove the case, should slide out with a little bit of effort.due to notches in the frame on the front top left ( when looking from the back).
  4. Sharp Microwave Door Switch Replacement, Microwave with the cover open: 4 단계, 이미지 3개 중 1개 Sharp Microwave Door Switch Replacement, Microwave with the cover open: 4 단계, 이미지 3개 중 2개 Sharp Microwave Door Switch Replacement, Microwave with the cover open: 4 단계, 이미지 3개 중 3개
    • Now we will identify the switches
    • The lower two switches
    • ... and the upper switch
    • Upper switch faulty
  5. Sharp Microwave Door Switch Replacement, Replacement of the switch: 5 단계, 이미지 3개 중 1개 Sharp Microwave Door Switch Replacement, Replacement of the switch: 5 단계, 이미지 3개 중 2개 Sharp Microwave Door Switch Replacement, Replacement of the switch: 5 단계, 이미지 3개 중 3개
    • Top switch appears loose
    • Replace and reinstall
    • Angled reinsertion to line up hole with plastic support
결론
작성자
2다른 기여자 명과 함께
Sanjay Don
회원 가입일: 12/24/17
229 평판
안내서 2개를 작성함
2가이드 댓글
Some Sharp Microwaves use different Torx screws. The T15 didn't fit the screws on my model, it appears to be the security version of the T15. I suggest getting a set such as the Mako instead.
DBDigital - 답글
Sometimes 2 of 6 cabinet screws are security style. Adjusting small needle nose vise-grip pliers very tightly and pointed directly around round screw head parallel to screw thread can loosen the sheet metal screw.
Gordy L - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 95
전체 시간: 5,642
