주요 콘텐츠로 건너뛰기
Sharp PC-MM20 Keyboard Replacement
필요한 것
  1. Sharp PC-MM20 Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • First, make sure the laptop is powered down. Then, remove the battery from the laptop.
  2. Sharp PC-MM20 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Sharp PC-MM20 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Close the laptop.
    • Turn the laptop so that the back is facing you.
    • There will be three screws on the back. Remove each screw by using the screw driver.
    • Keep the three screws in a safe place. A magnetic pad is an example of a safe place.
  3. Sharp PC-MM20 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Next, flip the laptop so that you can see the bottom.
    • Remove the screws shown in the picture.
  4. Sharp PC-MM20 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Sharp PC-MM20 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Next, open the laptop and focus on the front of the base of the laptop.
    • Notice that there are small notches in between the two plates of the laptop. There are several slots such as this that are found across the front base of the laptop.
    • Take a flat edge and wedge it into the slot to pop it open.
  5. Sharp PC-MM20 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Sharp PC-MM20 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Once the cover is loose, it should be able to shift somewhat freely. However, there are a few more connections holding it together.
    • Next, use tweezers to delicately remove the flat cable that connects the keyboard to the laptop.
    • Then, remove the flat cable from the track pad of the laptop.
  6. Sharp PC-MM20 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Now that all the connections are removed, remove the top of the base from the rest of the computer.
  7. Sharp PC-MM20 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Lastly, take the old keyboard out of the base and replace it with the new keyboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Logan Lindsey
회원 가입일: 09/11/13
128 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 759
