주요 콘텐츠로 건너뛰기
Sharp-EL-531xg Battery Replacement
필요한 것
  1. Sharp-EL-531xg Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Press the 2nd F button and then the OFF button to power down the calculator.
  2. Sharp-EL-531xg Battery Replacement: 2 단계, 이미지 1/2 Sharp-EL-531xg Battery Replacement: 2 단계, 이미지 2/2
    • Flip the calculator over so the back is facing upwards.
    • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
  3. Sharp-EL-531xg Battery Replacement: 3 단계, 이미지 1/1
    • Remove the battery cover using two fingers.
  4. Sharp-EL-531xg Battery Replacement: 4 단계, 이미지 1/3 Sharp-EL-531xg Battery Replacement: 4 단계, 이미지 2/3 Sharp-EL-531xg Battery Replacement: 4 단계, 이미지 3/3
    • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
    • Avoid using a sharp tool to remove the battery.
  5. Sharp-EL-531xg Battery Replacement: 5 단계, 이미지 1/1
    • Place the new battery into the slot with the positive (+) side facing upwards
    • Don't press the battery too hard.
  6. Sharp-EL-531xg Battery Replacement: 6 단계, 이미지 1/1
    • Put the battery cover back on.
    • Tighten the battery cover screw with a Phillips #0 screwdriver.
  7. Sharp-EL-531xg Battery Replacement: 7 단계, 이미지 1/2 Sharp-EL-531xg Battery Replacement: 7 단계, 이미지 2/2
    • Press the On button to turn on the calculator.
    • Flip the calculator over so the bottom is facing upwards.
    • Press the reset button with the pointed end of a spudger to restart the calculator.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Muhammad Hassan Majeed
회원 가입일: 01/17/22
166 평판
안내서 1개 작성함
York University, Team P-2, O'Regan Winter 2022 York University, Team P-2, O'Regan Winter 2022 회원
YORK-O'REGAN-W22SPG2
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 28
30일 전: 53
전체 시간: 692
