주요 콘텐츠로 건너뛰기
Sharper Image SVC430 Tripod Nut Replacement
필요한 것
  1. Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: 1 단계, 이미지 1/2 Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: 1 단계, 이미지 2/2
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Tripod Nut Replacement: 2 단계, 이미지 1/2 Sharper Image SVC430 Tripod Nut Replacement: 2 단계, 이미지 2/2
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Tripod Nut Replacement: 3 단계, 이미지 1/3 Sharper Image SVC430 Tripod Nut Replacement: 3 단계, 이미지 2/3 Sharper Image SVC430 Tripod Nut Replacement: 3 단계, 이미지 3/3
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Tripod Nut Replacement: 4 단계, 이미지 1/2 Sharper Image SVC430 Tripod Nut Replacement: 4 단계, 이미지 2/2
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Tripod Nut Replacement: 5 단계, 이미지 1/1
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Tripod Nut Replacement: 6 단계, 이미지 1/3 Sharper Image SVC430 Tripod Nut Replacement: 6 단계, 이미지 2/3 Sharper Image SVC430 Tripod Nut Replacement: 6 단계, 이미지 3/3
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Tripod Nut Replacement: 7 단계, 이미지 1/1
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Tripod Nut Replacement: 8 단계, 이미지 1/1
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Tripod Nut Replacement: 9 단계, 이미지 1/1
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Tripod Nut Replacement: 10 단계, 이미지 1/1
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Tripod Nut Replacement, Tripod Nut: 11 단계, 이미지 1/1
    • Locate the two screws that attach the tripod nut to the device.
  12. Sharper Image SVC430 Tripod Nut Replacement: 12 단계, 이미지 1/2 Sharper Image SVC430 Tripod Nut Replacement: 12 단계, 이미지 2/2
    • Unscrew the two screws located on the back of the half that the tripod nut is located.
    • Once the screws are removed, the tripod nut can easily be removed.
결론
Kathryn Mattingly
회원 가입일: 01/29/16
698 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 8
전체 시간: 214
