주요 콘텐츠로 건너뛰기
Sharper Image iPulse SI325 Outer Case Replacement
필요한 것
  1. Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: 1 단계, 이미지 1/2 Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: 1 단계, 이미지 2/2
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 Outer Case Replacement: 2 단계, 이미지 1/3 Sharper Image iPulse SI325 Outer Case Replacement: 2 단계, 이미지 2/3 Sharper Image iPulse SI325 Outer Case Replacement: 2 단계, 이미지 3/3
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 Outer Case Replacement: 3 단계, 이미지 1/2 Sharper Image iPulse SI325 Outer Case Replacement: 3 단계, 이미지 2/2
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
결론
Melissa Pasa
회원 가입일: 10/13/13
701 평판
안내서 7개 작성하였습니다
Cal Poly, Team 11-33, Amido Fall 2013 Cal Poly, Team 11-33, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G33
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 342
