주요 콘텐츠로 건너뛰기
Shenzhou k680e Silicone Grease Replacement
필요한 것
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: 1 단계, 이미지 1개 중 1개
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: 4 단계, 이미지 1개 중 1개
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: 7 단계, 이미지 1개 중 1개
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: 9 단계, 이미지 2개 중 1개 Shenzhou k680e Silicone Grease Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: 10 단계, 이미지 1개 중 1개
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: 11 단계, 이미지 1개 중 1개
    • Squeeze new thermal paste onto the chips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Yizhen Qu
회원 가입일: 09/20/20
217 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 98
지난 30일: 178
전체 시간: 872
