주요 콘텐츠로 건너뛰기
Shimano 6600 6700 Broken Gear Cable Replacement
  1. Shimano 6600 6700 Broken Gear Cable Replacement, Make a puller: 1 단계, 이미지 1개 중 1개
    • I used 1.6mm green plastic-covered plant wire from Bunnings. The wire needs to be bendable and yet stiff enough to hold a hook.
    • Strip the green plastic and bend the end 2mm
  2. Shimano 6600 6700 Broken Gear Cable Replacement, Insert hook and pull: 2 단계, 이미지 2개 중 1개 Shimano 6600 6700 Broken Gear Cable Replacement, Insert hook and pull: 2 단계, 이미지 2개 중 2개
    • Downshift as much as you can
    • Pull the brake to open
    • Insert the hook into the hole that the cable comes through, and then rotate it so that it holds where the cable bead normally sits
    • Close the brake so the wire is loosely held
    • Gently pull the wire while downshifting. You'll now be able to feel and hear the downshifting. Continue until it's fully downshifted
  3. Shimano 6600 6700 Broken Gear Cable Replacement, Remove the broken wire: 3 단계, 이미지 1개 중 1개
    • Pull the brake lever and you'll now be able to pull the broken wire out with long nose pliars
결론
작성자
2다른 기여자 명과 함께
Martin Hampton
회원 가입일: 02/13/16
1,329 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 40
전체 시간: 2,199
