주요 콘텐츠로 건너뛰기
Shop-Vac MC150A Filter Cage Replacement
필요한 것
  1. Shop-Vac MC150A Filter Cage Replacement, Unlatch the power unit assembly: 1 단계, 이미지 1/1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Filter Cage Replacement, Remove the foam sleeve: 2 단계, 이미지 1/1
    • Slide the foam sleeve up from the filter cage to remove it.
  3. Shop-Vac MC150A Filter Cage Replacement, Unscrew the filter cage: 3 단계, 이미지 1/1
    • Use a 3.5 mm hex key to remove the two screws securing the filter cage.
  4. Shop-Vac MC150A Filter Cage Replacement, Remove the filter cage: 4 단계, 이미지 1/1
    • Remove the filter cage.
결론
Ngunlian
회원 가입일: 02/08/16
732 평판
안내서 5개 작성하였습니다
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G2
5 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 1,737
