주요 콘텐츠로 건너뛰기
Shop-Vac MC150A Power Cable Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Shop-Vac MC150A Power Cable Replacement, Unlatch the power unit assembly: 1 단계, 이미지 1/1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Power Cable Replacement, Remove the top cover: 2 단계, 이미지 1/2 Shop-Vac MC150A Power Cable Replacement, Remove the top cover: 2 단계, 이미지 2/2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Power Cable Replacement: 3 단계, 이미지 1/1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Power Cable Replacement: 4 단계, 이미지 1/1
    • Separate the power unit assembly from the cover.
    Whereabout did you buy the replacement motor?
    HughP - 답글
  5. Shop-Vac MC150A Power Cable Replacement, Disconnect the switch: 5 단계, 이미지 1/3 Shop-Vac MC150A Power Cable Replacement, Disconnect the switch: 5 단계, 이미지 2/3 Shop-Vac MC150A Power Cable Replacement, Disconnect the switch: 5 단계, 이미지 3/3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Power Cable Replacement, Unscrew the motor bracket: 6 단계, 이미지 1/2 Shop-Vac MC150A Power Cable Replacement, Unscrew the motor bracket: 6 단계, 이미지 2/2
    • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
  7. Shop-Vac MC150A Power Cable Replacement: 7 단계, 이미지 1/2 Shop-Vac MC150A Power Cable Replacement: 7 단계, 이미지 2/2
    • During reassembly, be sure to reattach the green ground wire clip to the bracket.
  8. Shop-Vac MC150A Power Cable Replacement: 8 단계, 이미지 1/1
    • Separate the clip from the green wire and transfer it to the replacement motor.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ngunlian
회원 가입일: 02/08/16
732 평판
안내서 5개 작성하였습니다
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G2
5 회원들
안내서 13개 작성하였습니다
댓글 한 개
How and where do I order a power cord? Just any power? Or a specific for shop vac.
Jenny Sellman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 4,999
