소개
Follow this guide to remove and replace the power switch on the MC150A Shop-Vac.
필요한 것
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Use a 3.5 mm hex key to remove the three screws securing the top cover.
Remove the top cover.
Pull out and disconnect the four spade connectors from the switch module.
다른 6명이 해당 안내서를 완성하였습니다.
