주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shower Handle O-ring Replacement
필요한 것
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: 1 단계, 이미지 1개 중 1개
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
  2. Shower Handle O-ring  Replacement: 2 단계, 이미지 1개 중 1개
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
  3. Shower Handle O-ring  Replacement: 3 단계, 이미지 1개 중 1개
    • Using your groove joint pliers, loosen and remove the cartridge stem.
  4. Shower Handle O-ring  Replacement: 4 단계, 이미지 1개 중 1개
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
  5. Shower Handle O-ring  Replacement: 5 단계, 이미지 2개 중 1개 Shower Handle O-ring  Replacement: 5 단계, 이미지 2개 중 2개
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cori Fitzpatrick
회원 가입일: 03/20/16
213 평판
안내서 1개를 작성함
4가이드 댓글
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - 답글 공유
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - 답글 공유
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
Jess - 답글 공유
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 38
지난 30일: 193
전체 시간: 26,006
