주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shower Head Replacement
필요한 것
  1. Shower Head Replacement, Shower Head: 1 단계, 이미지 1개 중 1개
    • Use your hand to loosen the old shower head from the pipe. This should be fairly easy, as most shower heads have a textured grip on the joint.
    • Make sure the water is turned off to the shower.
  2. Shower Head Replacement: 2 단계, 이미지 1개 중 1개
    • Once the shower head is loosened, remove it and set it aside.
  3. Shower Head Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the old plumbing tape from the threads of the pipe, and throw it away.
  4. Shower Head Replacement: 4 단계, 이미지 1개 중 1개
    • Grab your roll of plumbing tape and wrap the tape approximately twice around the threads of the pipe.
    • Be sure to wrap the tape tightly to prevent leaks.
  5. Shower Head Replacement: 5 단계, 이미지 1개 중 1개
    • Begin installing the new shower head by threading it onto the pipe.
  6. Shower Head Replacement: 6 단계, 이미지 1개 중 1개
    • Use your hands to tighten the new shower head back onto the pipe, using a wrench if needed.
    • Make sure it is tightly connected!
  7. Shower Head Replacement: 7 단계, 이미지 1개 중 1개
    • Turn on the water and enjoy your new shower head!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Aaron Bartfeld
회원 가입일: 02/23/15
205 평판
안내서 1개를 작성함
Cal Poly, Team 12-3, Green Winter 2015 Cal Poly, Team 12-3, Green Winter 2015 회원
CPSU-GREEN-W15S12G3
4 회원들
안내서 7개를 작성함
4가이드 댓글
Great post. Very informative and easy to follow! Beautiful hand model, absolutely superb! Is he single by any chance?
nprewitt - 답글 공유
My shower isn’t broken I just keep looking at the incredible hand model! Wow! I would break my shower head if these hands would fix it
Abby - 답글 공유
What a helpful guide . And Wow! I couldn't help but notice some phenomenal hand modeling. Those hands are going places that's for sure!
Ronaldo Villa - 답글 공유
What does his feet look like? Haha.
Sounds like fake replies. 3 people saying the same thing on the same exact day. Gtfoh.
Kimmy (Kimmy Kimmy Bang Bang) - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 81
전체 시간: 3,854
