주요 콘텐츠로 건너뛰기
ShowerDoorDirect Shower Speaker Battery Replacement
필요한 것
  1. ShowerDoorDirect Shower Speaker Battery Replacement, Battery: 1 단계, 이미지 1/2 ShowerDoorDirect Shower Speaker Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the suction pad by pulling the suction out of the slot that it is in.
  2. ShowerDoorDirect Shower Speaker Battery Replacement: 2 단계, 이미지 1/1
    • Remove the four 9.09mm Philips #1 screws that hold the 2 pieces of the cover together.
    • Pull apart the two halves.
  3. ShowerDoorDirect Shower Speaker Battery Replacement: 3 단계, 이미지 1/1
    • Hold the base and pull up on the battery.
  4. ShowerDoorDirect Shower Speaker Battery Replacement: 4 단계, 이미지 1/3 ShowerDoorDirect Shower Speaker Battery Replacement: 4 단계, 이미지 2/3 ShowerDoorDirect Shower Speaker Battery Replacement: 4 단계, 이미지 3/3
    • Remove the four 5mm Phillips #1 screws from the motherboard.
    • Desolder the two wires connecting the battery tp the motherboard.
결론
Matthew Dunkle
회원 가입일: 05/21/18
203 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G1, Harley Spring 2018 IUPUI, Team S1-G1, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G1
7 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 543
