주요 콘텐츠로 건너뛰기
Shure SM58 Capsule Installation Replacement
필요한 것
  1. Shure SM58 Capsule Installation Replacement, Collar: 1 단계, 이미지 1/3 Shure SM58 Capsule Installation Replacement, Collar: 1 단계, 이미지 2/3 Shure SM58 Capsule Installation Replacement, Collar: 1 단계, 이미지 3/3
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. Shure SM58 Capsule Installation Replacement, Faceplate: 2 단계, 이미지 1/1
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
    Why should I replace the plate?
    Gerrit - 답글
    This guide was done as part of the capsule replacement—I don’t think there is any reason to solely replace the plate unless there was corrosion on it.
    Daniel Berger - 답글
  3. Shure SM58 Capsule Installation Replacement: 3 단계, 이미지 1/2 Shure SM58 Capsule Installation Replacement: 3 단계, 이미지 2/2
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  4. Shure SM58 Capsule Installation Replacement: 4 단계, 이미지 1/2 Shure SM58 Capsule Installation Replacement: 4 단계, 이미지 2/2
    • Slide the face plate over the connector.
  5. Shure SM58 Capsule Installation Replacement, Capsule Installation: 5 단계, 이미지 1/2 Shure SM58 Capsule Installation Replacement, Capsule Installation: 5 단계, 이미지 2/2
    • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
  6. Shure SM58 Capsule Installation Replacement: 6 단계, 이미지 1/1
    • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
    Step 6 is incorrect. The grill screws off counter clockwise.
    Bill Kahler - 답글
  7. Shure SM58 Capsule Installation Replacement: 7 단계, 이미지 1/1
    • Slide the grille off the top of the microphone once it is all the way loosened.
  8. Shure SM58 Capsule Installation Replacement: 8 단계, 이미지 1/3 Shure SM58 Capsule Installation Replacement: 8 단계, 이미지 2/3 Shure SM58 Capsule Installation Replacement: 8 단계, 이미지 3/3
    • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
    • Slowly, pull upward while twisting the black plastic piece clockwise.
    • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
    • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
    Can you replace the yellow tape/cable if broken? (seen in last pic)
    karl_ivers - 답글
    Honestly, I’m not sure. If I was in your position, I would assume a similarly sized piece of electrical tape should be fine, but if you’re not sure you may want to contact a repairman.
    Daniel Berger - 답글
결론
Once installed, reassemble the microphone following the steps in reverse.
다른 7명이 해당 안내서를 완성하였습니다.
nat coll
회원 가입일: 09/27/12
642 평판
안내서 14개 작성하였습니다
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 20개 작성하였습니다
댓글 5개
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - 답글
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger -
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - 답글
You can unscrew just the grill.
Burke McQuinn - 답글
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 60
30일 전: 246
전체 시간: 39,333
