주요 콘텐츠로 건너뛰기
Shure SM58 Faceplate Replacement
필요한 것
  1. Shure SM58 Faceplate Replacement, Faceplate: 1 단계, 이미지 1/1
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
  2. Shure SM58 Faceplate Replacement: 2 단계, 이미지 1/2 Shure SM58 Faceplate Replacement: 2 단계, 이미지 2/2
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  3. Shure SM58 Faceplate Replacement: 3 단계, 이미지 1/2 Shure SM58 Faceplate Replacement: 3 단계, 이미지 2/2
    • Slide the face plate over the connector.
결론
Follow the steps of the guide in reverse to reassemble the microphone. In order to solder wires back to faceplate use soldering guide.
nat coll
회원 가입일: 09/27/12
642 평판
안내서 14개 작성하였습니다
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 29
전체 시간: 8,770
