주요 콘텐츠로 건너뛰기
Shure SM58 Grille Replacement
  1. Shure SM58 Grille Replacement, Grille: 1 단계, 이미지 1/1
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Shure SM58 Grille Replacement: 2 단계, 이미지 1/2 Shure SM58 Grille Replacement: 2 단계, 이미지 2/2
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
결론
Follow the steps in reverse to install the new grille on the microphone.
다른 5명이 해당 안내서를 완성하였습니다.
nat coll
회원 가입일: 09/27/12
642 평판
안내서 14개 작성하였습니다
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 20개 작성하였습니다
댓글 2개
Can you change the grilles of sm58 and sm86?
Jack - 답글
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 35
전체 시간: 10,016
