소개
The XLR Connector is the part of the microphone that plugs into the cable which carries the sound to the sound mixer and speakers.
필요한 것
Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
After soldering the wires to the XLR connector and reassembling your microphone, your microphone should be ready to plug in to the XLR cable and function properly.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 9개
I'm not familiar with the "pin 2 hot method." We took a working mic apart and reassembled it the way we found it, so I'm pretty that is the correct soldering configuration.
Świetna strona. Brawo.
