주요 콘텐츠로 건너뛰기
Shure SM58 XLR Microphone Connector Installation Replacement
필요한 것
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: 1 단계, 이미지 1/1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: 2 단계, 이미지 1/1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: 3 단계, 이미지 1/1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
결론
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
다른 4명이 해당 안내서를 완성하였습니다.
Ronald Lam
회원 가입일: 09/27/12
307 평판
안내서 1개 작성함
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 20개 작성하였습니다
댓글 7개
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - 답글
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - 답글
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - 답글
Are the threads on your screw stripped?
Daniel Berger - 답글
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - 답글
I would take your microphone into your local ACE and see if they can help you find the right size
Daniel Berger -
Very good advice ! Thanks
pat.i - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 39
전체 시간: 10,552
