주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sidekick II Outer Casing Replacement
필요한 것
  1. Sidekick II Outer Casing Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Outer Casing Replacement: 2 단계, 이미지 2개 중 1개 Sidekick II Outer Casing Replacement: 2 단계, 이미지 2개 중 2개
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Outer Casing Replacement: 3 단계, 이미지 1개 중 1개
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Outer Casing Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Outer Casing Replacement: 5 단계, 이미지 1개 중 1개
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
결승점
작성자
7다른 기여자 명과 함께
michael albaum
회원 가입일: 01/20/10
108 평판
안내서 6개를 작성함
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 회원
CPSU-MANESS-W10S3G19
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 67
전체 시간: 2,797
