주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Taking out the thumbwheel.
  1. Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Remove 2 screws using the Torx 6 screwdriver.
    • Remove 2 screws using the Torx 6 screwdriver.
  7. The thumbwheel and casing will be loose, gently remove it.
    • The thumbwheel and casing will be loose, gently remove it.
결승점
michael albaum
회원 가입일: 2010년 01월 20일
66 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 회원
CPSU-MANESS-W10S3G19
4 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,076
