주요 콘텐츠로 건너뛰기
Siemens A56 Clean Charging Port Replacement
필요한 것
  1. Siemens A56 Clean Charging Port Replacement, Battery: 1 단계, 이미지 1/1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Clean Charging Port Replacement: 2 단계, 이미지 1/1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Clean Charging Port Replacement, Clean Charging Port: 3 단계, 이미지 1/1
    • Use soft brush to clean the charging port of the phone. If needed, use alcohol and a q-tip for more thorough cleaning.
결승점
Lauren Young
회원 가입일: 03/26/14
322 평판
안내서 3개 작성하였습니다
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 회원
CLEM-BENSON-S14S6G6
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 257
