주요 콘텐츠로 건너뛰기
Siemens A56 Keyboard Replacement
  1. Siemens A56 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Keyboard Replacement, Front Plate: 3 단계, 이미지 3개 중 1개 Siemens A56 Keyboard Replacement, Front Plate: 3 단계, 이미지 3개 중 2개 Siemens A56 Keyboard Replacement, Front Plate: 3 단계, 이미지 3개 중 3개
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  4. Siemens A56 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 Siemens A56 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 Siemens A56 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    • The keyboard can be easily removed by hand.
    • Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
결론
작성자
4다른 기여자 명과 함께
Andrew Corriveau
회원 가입일: 03/26/14
97 평판
안내서 1개를 작성함
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 회원
CLEM-BENSON-S14S6G6
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 272
