주요 콘텐츠로 건너뛰기
Siemens A56 SIM Card Replacement
필요한 것
  1. Siemens A56 SIM Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 SIM Card Replacement: 2 단계, 이미지 1개 중 1개
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 1개 Siemens A56 SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 2개 Siemens A56 SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 3개
    • With the phone turned onto its backside, gently slide the metal clasp up to unlock the SIM card.
    • It may be easier to move the clasp with a plastic opening tool, but it is not required.
    • The SIM card will spring up once the clasp is released.
    • Remove the SIM card from phone.
  4. Siemens A56 SIM Card Replacement: 4 단계, 이미지 3개 중 1개 Siemens A56 SIM Card Replacement: 4 단계, 이미지 3개 중 2개 Siemens A56 SIM Card Replacement: 4 단계, 이미지 3개 중 3개
    • To replace the SIM card, insert the card back into the slot.
    • While pressing the SIM card with one finger, slide the metal clasp down to lock the card in place.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lauren Young
회원 가입일: 03/26/14
322 평판
안내서 3개를 작성함
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 회원
CLEM-BENSON-S14S6G6
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 653
