주요 콘텐츠로 건너뛰기
Siemens-Maquet Servo-i Bacteria Filter Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
  1. Siemens-Maquet Servo-i Bacteria Filter Replacement, Filter for Gas Modules: 1 단계, 이미지 1/1
    • When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used
    • Remove the inspiratory section cover
    • Loosen the screw (1)
    • Lift off the gas module bracket (2)
    • Service Manual 4 - 14
  2. Siemens-Maquet Servo-i Bacteria Filter Replacement: 2 단계, 이미지 1/1
    • Pull out and lift off both gas modules.
  3. Siemens-Maquet Servo-i Bacteria Filter Replacement: 3 단계, 이미지 1/1
    • Note 1: When assembling, make sure that the connector muff properly seals around the inspiratory pipe (1). The connector muff must not be pushed too far onto the nozzle units (2)
    • Note 2: The gas modules used in Servo-i are factory adjusted for this purpose. When replacing gas modules, make sure to use only Servo-i gas modules.Similar gas modules intended for the SV 300/300A or KION / KION-i Systems must not be used.
  4. Siemens-Maquet Servo-i Bacteria Filter Replacement: 4 단계, 이미지 1/1
    • Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
    • Service Manual 7 - 3
  5. Siemens-Maquet Servo-i Bacteria Filter Replacement, Bacteria Filter for O2 Cell: 5 단계, 이미지 1/1
    • Twist off white filter cap.
    • Service Manual 7 - 4
    • Use the Maintenance kit, 5,000 hours to replace the bacteria filter for the O2 cell.
결론
rachel davis
회원 가입일: 04/19/18
110 평판
안내서 1개 작성함
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Cal Poly, Team S1-G2, Zimmerman Spring 2020 회원
CPSU-ZIMMERMAN-S20S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 430
