주요 콘텐츠로 건너뛰기
Siemens-Maquet Servo-i Battery Module Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
    • Check the battery date. The battery needs replacing after 3 years.
    • The manufacturing date is listed in the format (year-week) on the battery label.
    • Servo-i User Manual page 19.
    • If battery status on touchpad display is red make sure to replace battery modules.
    • At least one battery module must be installed at all times. If not the ventilator will not work properly.
    • Store uninstalled batteries at 15-20 degrees celsius.
  1. Siemens-Maquet Servo-i Battery Module Replacement: 3 단계, 이미지 1/1
    • Wait for the battery to be fully charged.
    • To check this, press the battery power symbol button on the battery.
    • All four LED's must be lit.
    • Servo-i User Manual page 20.
  2. Siemens-Maquet Servo-i Battery Module Replacement: 4 단계, 이미지 1/1
    • With gas, patient tubes and test lung connected, let the Servo-i run in a ventilation mode.
    • Disconnect mains power to the unit to allow battery operation.
    • Allow ventilator to run and make sure 'No battery capacity'- alarm is not activated.
    • Servo-i Service Manual 5-2.
  3. Siemens-Maquet Servo-i Battery Module Replacement: 5 단계, 이미지 1/1
    • The time between the 'Limited battery capacity'- alarm and the 'No battery capacity' alarm must not exceed 7 minutes.
    • The event log contains the records of alarm times.
  4. Siemens-Maquet Servo-i Battery Module Replacement: 6 단계, 이미지 1/3 Siemens-Maquet Servo-i Battery Module Replacement: 6 단계, 이미지 2/3 Siemens-Maquet Servo-i Battery Module Replacement: 6 단계, 이미지 3/3
    • See if the upper part of the module is equipped with a latch. This means it is fixed and follow these instructions to disassemble a battery from the battery module.
    • 1. Locate a small hexagonal wrench or screwdriver.
    • Place the tool in the small hole on the right hand side.
    • 2. Simultaneously push the release button.
    • 3. Remove the tool, while still pressing the release button.
    • 4. Continue to keep the button pressed until the battery pops out.
    • 5. Pull out the battery module.
    • Servo-i Service Manual 4-18.
결론
Monroe Erle
회원 가입일: 05/04/20
133 평판
안내서 1개 작성함
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Cal Poly, Team S1-G2, Zimmerman Spring 2020 회원
CPSU-ZIMMERMAN-S20S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 28
전체 시간: 1,017
