주요 콘텐츠로 건너뛰기
Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
  1. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement, Filter for Gas Modules: 1 단계, 이미지 1/1
    • When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used
    • Remove the inspiratory section cover
    • Loosen the screw (1)
    • Lift off the gas module bracket (2)
    • Service Manual 4 - 14
  2. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: 2 단계, 이미지 1/1
    • Pull out and lift off both gas modules.
  3. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: 3 단계, 이미지 1/1
    • Note 1: When assembling, make sure that the connector muff properly seals around the inspiratory pipe (1). The connector muff must not be pushed too far onto the nozzle units (2)
    • Note 2: The gas modules used in Servo-i are factory adjusted for this purpose. When replacing gas modules, make sure to use only Servo-i gas modules.Similar gas modules intended for the SV 300/300A or KION / KION-i Systems must not be used.
  4. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: 4 단계, 이미지 1/1
    • Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
    • Service Manual 7 - 3
  5. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement, Pressure Transducer Filter: 5 단계, 이미지 1/1
    • Replace plastic nozzle units in the gas modules.
    • After replacement of plastic nozzle units, wait 10 minutes before connecting pressure to the gas modules
    • Service Manual 7 - 4
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maria Brown
회원 가입일: 05/04/20
196 평판
안내서 2개 작성하였습니다
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Cal Poly, Team S1-G2, Zimmerman Spring 2020 회원
CPSU-ZIMMERMAN-S20S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 23
전체 시간: 482
