주요 콘텐츠로 건너뛰기
Signode BXT3-16 Strapping Combo Tool Spring Replacement
필요한 것
  1. Signode BXT3-16 Strapping Combo Tool Spring Replacement, Spring: 1 단계, 이미지 1개 중 1개
    • Before dismantling the strapping gun, ensure the power source / battery is removed.
  2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the strapping gun upside down.
    • Place it on a flat surface to keep the strapping gun stable during repair.
    • There are four Torx T4 screws on the bottom of the tool.
  3. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 3 단계, 이미지 3개 중 1개 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 3 단계, 이미지 3개 중 2개 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 3 단계, 이미지 3개 중 3개
    • Use the Torx T4 screwdriver to remove the four 25 mm screws from the base plate.
    • Remove the single 25 mm Torx T4 screw from the front side of the strapping gun.
    • Use a Torx T4 screwdriver to remove the two 25 mm screws on the front of the tool.
  4. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 4 단계, 이미지 1개 중 1개
    • Rotate the strapping gun to the opposite side.
    • Use the Torx T4 screwdriver to remove the remaining 25 mm screws from the front of the strapping gun.
  5. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 5 단계, 이미지 2개 중 1개 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 5 단계, 이미지 2개 중 2개
    • Rotate the strapping tool to the original position, with the model number and name facing you.
    • Firmly pull the guard plate and the tool apart using both hands.
  6. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 6 단계, 이미지 2개 중 1개 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 6 단계, 이미지 2개 중 2개
    • Use a metal spudger to lift the cutter.
    • Gently, push the spring out from the bottom of the base of the strapping gun.
  7. Signode BXT3-16 Strapping Combo Tool Spring Replacement: 7 단계, 이미지 3개 중 1개 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 7 단계, 이미지 3개 중 2개 Signode BXT3-16 Strapping Combo Tool Spring Replacement: 7 단계, 이미지 3개 중 3개
    • Rotate the machine to remove the spring gently by hand.
    • Remove the spring from the base of the strapping tool.
    • Replace with new spring by inserting it the same way it was removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jainam Shah
회원 가입일: 02/01/24
172 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 41
전체 시간: 834
