주요 콘텐츠로 건너뛰기
Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement
필요한 것
  1. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement, Magnet positional sensor: 1 단계, 이미지 1/1
    • Ensure the power connector is switched OFF before plugging in or unplugging the wheelbase. Leaving it on while plugging or unplugging the power connector could damage your device.
    • Turn the power off.
  2. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 2 단계, 이미지 1/1
    • Disconnect all cables from the wheelbase.
  3. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 3 단계, 이미지 1/2 Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 3 단계, 이미지 2/2
    • Use a 2.5 mm Hex Key to remove the two 10 mm screws that connect the wheelbase to the mounting plate.
  4. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 4 단계, 이미지 1/1
    • Lay the wheelbase right side up, ensuring the "Simagic" logo is on top.
  5. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 5 단계, 이미지 1/2 Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 5 단계, 이미지 2/2
    • Rotate the wheelbase 180 degrees so the bolts on the back of the device are facing you.
    • Use a 2.5mm M3 Hex Key to remove four 4 mm screws.
  6. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 6 단계, 이미지 1/1
    • Open the electronics cover.
    • As you open the electronics cover, be careful not to unplug or tear the wires connecting the cover to the wheelbase.
  7. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 7 단계, 이미지 1/2 Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 7 단계, 이미지 2/2
    • Use a 1.5mm M1 Hex Key two remove two 5 mm screws from the back magnet.
  8. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 8 단계, 이미지 1/2 Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 8 단계, 이미지 2/2
    • Turn the wheel shaft until the Wi-Fi symbol is facing up.
    • The wheelbase was rotated 180 degrees in this picture. However, if your workspace allows it, leave the device with the back facing you, like in the previous step.
  9. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 9 단계, 이미지 1/2 Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 9 단계, 이미지 2/2
    • Ensure the Wi-Fi symbol located on the front of the wheelbase is facing straight up prior to turning the magnet.
    • Turn the magnet clockwise until one of the screw holes is facing up and the other screw hole is facing right to realign the positional sensor (magnet).
  10. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 10 단계, 이미지 1/1
    • Use a 1.5 mm M1 Hex Key to tighten two 5 mm screws and secure the sensor into position.
  11. Simagic Alpha Mini Direct Drive Wheelbase Magnet Positional Sensor Replacement: 11 단계, 이미지 1/1
    • To check if you have aligned the sensor correctly, launch the Alpha Manager application. On the screen that follows, ensure the wheel is 0.0.
결론
Hugo Lai
회원 가입일: 02/05/24
193 평판
안내서 1개 작성함
York University, Team M-6, Allen Winter 2024 York University, Team M-6, Allen Winter 2024 회원
YORK-ALLEN-W24SMG6
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 27
전체 시간: 112
