주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SimpliSafe Original Base Station Cellular Chip Module Replacement
필요한 것
  1. SimpliSafe Original Base Station Cellular Chip Module Replacement, Prepare your Base Station: 1 단계, 이미지 1개 중 1개
    • Make sure you perform the work on a flat well-lit surface.
  2. SimpliSafe Original Base Station Cellular Chip Module Replacement, Turn the Base Station on the side and twist to remove the top cover: 2 단계, 이미지 2개 중 1개 SimpliSafe Original Base Station Cellular Chip Module Replacement, Turn the Base Station on the side and twist to remove the top cover: 2 단계, 이미지 2개 중 2개
    • Grasp the base of the Base Station with one hand and the upper part near the center while slowly twisting counter clockwise and up.
  3. SimpliSafe Original Base Station Cellular Chip Module Replacement, Fully remove the top cover: 3 단계, 이미지 1개 중 1개
    • Set the top cover somewhere to the side and in a safe area—you won't need this until reassembly.
  4. SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the cellular chip module: 4 단계, 이미지 3개 중 1개 SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the cellular chip module: 4 단계, 이미지 3개 중 2개 SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the cellular chip module: 4 단계, 이미지 3개 중 3개
    • Turn the Base Station on its side to achieve a better angle for the disassembly.
    • Use a Phillips #1 screwdriver bit to remove 3 screws securing the chip module to the rest of the base station.
    • After you remove the screws, you'll need to disconnect the cable connecting the two chip boards that are secured with an FPC connector.
    • Use your fingers to grip the two edges of the cable and firmly pull up while holding the board down. Do so carefully so as not to remove the soldered connector from the board.
  5. SimpliSafe Original Base Station Cellular Chip Module Replacement, Remove the FPC Connector Cable: 5 단계, 이미지 1개 중 1개
    • Remove the connector link cable between the two boards after disconnecting the cellular chip board.
    • Use the same method as before, gripping just the edges of the connector and pulling up.
  6. SimpliSafe Original Base Station Cellular Chip Module Replacement, Install the new chip module: 6 단계, 이미지 1개 중 1개
    • Resecure the FPC Connecting cable to the board and to the new chip module.
    • Use the three Phillips #1 screws from the earlier step and resecure the module to the base station.
  7. SimpliSafe Original Base Station Cellular Chip Module Replacement, Reassemble your Base Station: 7 단계, 이미지 1개 중 1개
    • Reattach the Base Station cover.
    • SimpliSafe provides you with a prepaid label and ESD-safe bubble wrap to ship back the old module for recycling.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matt Zieminski
회원 가입일: 02/23/14
175 평판
안내서 1개를 작성함
iPhone Repairs by Matt iPhone Repairs by Matt 회원
Business
1 회원
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 26
전체 시간: 3,012
