주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement
필요한 것
  1. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement, Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 1 단계, 이미지 2개 중 1개 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement, Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 1 단계, 이미지 2개 중 2개
    • To adjust the tension, spin the dial located above the needle.
    • The default setting is 5. A higher number increases thread tension, and a lower number decreases thread tension.
    • WARNING: Having the tension too high may cause the needle to snap.
  2. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 2 단계, 이미지 2개 중 1개 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 2 단계, 이미지 2개 중 2개
    • To test the thread tension, take a scrap piece of fabric and sew a short line.
    • If the thread is getting bunched up leaving an incomplete line, the tension is likely too high. Proper tension will leave a straight, completed line.
    • Adjust thread tension as needed and retest until it is correct.
  3. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 3 단계, 이미지 1개 중 1개
    • To replace a needle, begin by unscrewing the screw located to the right of the needle.
    • Rotate the screw away from you to loosen the screw.
  4. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 4 단계, 이미지 1개 중 1개
    • Singer needles commonly come in small packs such as these.
    • There are different types of needles, but the most common needles are the 80/12 Universal Needles.
    • If you're sewing a heavy-weight fabric, you may choose a heavy duty needle to avoid snapping the needle.
  5. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the needle. Replace the needle with a fresh needle.
    • Rotate the screw away from you to tighten the screw.
    • Make sure the you hold the needle in place when tightening the screw to ensure correct needle placement.
  6. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 6 단계, 이미지 3개 중 1개 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 6 단계, 이미지 3개 중 2개 Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 6 단계, 이미지 3개 중 3개
    • Another reason the sewing machine is not sewing properly might be due to a misaligned bobbin.
    • To check the bobbin, remove the front section of the sewing machine by firmly sliding the section to the left.
    • Open the hinge door towards you to reveal the bobbin.
    • Check to see if the bobbin is firmly in place. If the bobbin is loose, shift the bobbin to fit firmly in place.
  7. Singer Brilliance 6180 Thread Tension Adjustment and Needle Replacement: 7 단계, 이미지 1개 중 1개
    • This is how the bobbin should look.
결승점
작성자
2다른 기여자 명과 함께
Emma Arntzen
회원 가입일: 02/20/25
145 평판
안내서 1개를 작성함
UC Davis, Team 1-2, Andersen Winter 2025 UC Davis, Team 1-2, Andersen Winter 2025 회원
UCD-ANDERSEN-W25S1G2
4 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 67
전체 시간: 629
