주요 콘텐츠로 건너뛰기
Singing Machine Shine Duets Motherboard Replacement
필요한 것
  1. Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: 1 단계, 이미지 1/3 Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: 1 단계, 이미지 2/3 Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: 1 단계, 이미지 3/3
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets Motherboard Replacement: 2 단계, 이미지 1/3 Singing Machine Shine Duets Motherboard Replacement: 2 단계, 이미지 2/3 Singing Machine Shine Duets Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets Motherboard Replacement: 3 단계, 이미지 1/3 Singing Machine Shine Duets Motherboard Replacement: 3 단계, 이미지 2/3 Singing Machine Shine Duets Motherboard Replacement: 3 단계, 이미지 3/3
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets Motherboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • The motherboard is located right behind the control buttons.
  5. Singing Machine Shine Duets Motherboard Replacement: 5 단계, 이미지 1/2 Singing Machine Shine Duets Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the two screws holding the LED board in place.
  6. Singing Machine Shine Duets Motherboard Replacement: 6 단계, 이미지 1/2 Singing Machine Shine Duets Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove both LED boards from their pins.
  7. Singing Machine Shine Duets Motherboard Replacement: 7 단계, 이미지 1/2 Singing Machine Shine Duets Motherboard Replacement: 7 단계, 이미지 2/2
    • Detach the white cable from its connector on the motherboard.
  8. Singing Machine Shine Duets Motherboard Replacement: 8 단계, 이미지 1/2 Singing Machine Shine Duets Motherboard Replacement: 8 단계, 이미지 2/2
    • Carefully disconnect this red-and-black wire from the motherboard.
  9. Singing Machine Shine Duets Motherboard Replacement: 9 단계, 이미지 1/2 Singing Machine Shine Duets Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the thicker red-and-black wire from its socket on the motherboard.
  10. Singing Machine Shine Duets Motherboard Replacement: 10 단계, 이미지 1/3 Singing Machine Shine Duets Motherboard Replacement: 10 단계, 이미지 2/3 Singing Machine Shine Duets Motherboard Replacement: 10 단계, 이미지 3/3
    • Disconnect the red port on the board which holds all of the external plugs
    • Disconnect the white wires from the board.
  11. Singing Machine Shine Duets Motherboard Replacement: 11 단계, 이미지 1/2 Singing Machine Shine Duets Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
  12. Singing Machine Shine Duets Motherboard Replacement: 12 단계, 이미지 1/3 Singing Machine Shine Duets Motherboard Replacement: 12 단계, 이미지 2/3 Singing Machine Shine Duets Motherboard Replacement: 12 단계, 이미지 3/3
    • Remove the motherboard from the shell.
결론
Ethan Dodson
회원 가입일: 02/09/23
533 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 168
