주요 콘텐츠로 건너뛰기
Single-Speed Bicycle Chain Replacement
필요한 것
  1. Single-Speed Bicycle Chain Replacement, Chain: 1 단계, 이미지 2개 중 1개 Single-Speed Bicycle Chain Replacement, Chain: 1 단계, 이미지 2개 중 2개
    • Flip the bike upside down for easy access to the rear wheel and chain.
  2. Single-Speed Bicycle Chain Replacement: 2 단계, 이미지 2개 중 1개 Single-Speed Bicycle Chain Replacement: 2 단계, 이미지 2개 중 2개
    • Use either an Allen or crescent wrench to loosen the nuts of the rear wheel of the bike. Make sure to do this on both sides of the wheel.
    • This step will require a 5mm Allen wrench or a crescent wrench, depending on the type of wheels you have.
  3. Single-Speed Bicycle Chain Replacement: 3 단계, 이미지 2개 중 1개 Single-Speed Bicycle Chain Replacement: 3 단계, 이미지 2개 중 2개
    • Place the chain breaker tool over the old chain.
    • Insert a link of the old chain into the chain breaker tool.
  4. Single-Speed Bicycle Chain Replacement: 4 단계, 이미지 3개 중 1개 Single-Speed Bicycle Chain Replacement: 4 단계, 이미지 3개 중 2개 Single-Speed Bicycle Chain Replacement: 4 단계, 이미지 3개 중 3개
    • Turn the knob on the chain breaker tool until the pin within the chain has popped out.
    • Remove the old chain.
    • This step may take some finesse to ensure that the pin falls out.
  5. Single-Speed Bicycle Chain Replacement: 5 단계, 이미지 2개 중 1개 Single-Speed Bicycle Chain Replacement: 5 단계, 이미지 2개 중 2개
    • Unbox the new chain and place it on the chain ring.
    • Align the rings with the gears to ensure a proper fit.
  6. Single-Speed Bicycle Chain Replacement: 6 단계, 이미지 3개 중 1개 Single-Speed Bicycle Chain Replacement: 6 단계, 이미지 3개 중 2개 Single-Speed Bicycle Chain Replacement: 6 단계, 이미지 3개 중 3개
    • Wrap the chain around the cog of the rear wheel and bring the two ends of the chain together.
    • The chain should be long enough so that it can move up and down ~1/2 inch when secured.
    • Remove the excess chain using the chain breaker tool. Refer to steps 3 and 4 for how to use the chain breaker tool.
  7. Single-Speed Bicycle Chain Replacement: 7 단계, 이미지 3개 중 1개 Single-Speed Bicycle Chain Replacement: 7 단계, 이미지 3개 중 2개 Single-Speed Bicycle Chain Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the master link of the chain.
    • A master link is a single removable link segment on a bike chain. It connects the two ends of the chain together.
    • Insert the link pins into the two ends of the chain.
  8. Single-Speed Bicycle Chain Replacement: 8 단계, 이미지 2개 중 1개 Single-Speed Bicycle Chain Replacement: 8 단계, 이미지 2개 중 2개
    • Place the link face onto the link pins.
    • The chain is now secured.
  9. Single-Speed Bicycle Chain Replacement: 9 단계, 이미지 3개 중 1개 Single-Speed Bicycle Chain Replacement: 9 단계, 이미지 3개 중 2개 Single-Speed Bicycle Chain Replacement: 9 단계, 이미지 3개 중 3개
    • Once the chain is on, pull the rear wheel back.
    • Tighten the nut on the drive side (right side) of the rear wheel.
    • The drive side of a bike is the side with the gears. This is usually on the right side, as seen in this model.
  10. Single-Speed Bicycle Chain Replacement: 10 단계, 이미지 2개 중 1개 Single-Speed Bicycle Chain Replacement: 10 단계, 이미지 2개 중 2개
    • Push the front end of the rear wheel to the non-drive side (left side) of the wheel. This pulls on the chain, creating tension.
    • Tighten the nut on the non-drive side (left side) of the wheel.
  11. Single-Speed Bicycle Chain Replacement: 11 단계, 이미지 1개 중 1개
    • Repeat the previous step with the drive side (right side) until the wheel is tightened.
    • Ensure that both nuts are tightened evenly.
  12. Single-Speed Bicycle Chain Replacement: 12 단계, 이미지 3개 중 1개 Single-Speed Bicycle Chain Replacement: 12 단계, 이미지 3개 중 2개 Single-Speed Bicycle Chain Replacement: 12 단계, 이미지 3개 중 3개
    • Check the tension in the gear.
    • It is good to have about half an inch of play in the chain in both directions.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
SaniaHey
회원 가입일: 01/31/24
214 평판
안내서 1개를 작성함
UC Davis, Team 1-7, Andersen Winter 2024 UC Davis, Team 1-7, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S1G7
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 40
지난 30일: 157
전체 시간: 2,267
