주요 콘텐츠로 건너뛰기
소개
The old volume button is removed by pushing the pushing the volume button upwards and popping it out of the device's case. The new volume button is installed by simply snapping it into volume button slot of the case..
부품
지정된 부품이 없습니다.
  1. Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal. Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Use a Philip's head screw driver to remove the screws from the case. Place the screws in a small container to avoid losing them.
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Remove the front cover. First, insert a small pry bar where the black front cover and white back cover meet. Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover. Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
  7. Locate the volume button on the side of the device.  The volume button is indicated with an orange rectangle in the photograph.
    • Locate the volume button on the side of the device. The volume button is indicated with an orange rectangle in the photograph.
  8. Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
    • Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
  9. Push on the volume button with both of your thumbs.  Wiggle the volume button back and forth as you push upwards.
    • Push on the volume button with both of your thumbs. Wiggle the volume button back and forth as you push upwards.
    • The volume button will pop out.
  10. Remove the volume button from the device.
    • Remove the volume button from the device.
  11. Slide the new volume button into the slot for the volume button.
    • Slide the new volume button into the slot for the volume button.
    • Make sure that the volume button is oriented correctly. An easy way to check this is to hold the volume button in place and look at the side of the device.
  12. Push down on the volume button to snap it back into the case.
    • Push down on the volume button to snap it back into the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Morgan McDougald
회원 가입일: 2012년 03월 09일
71 평판
안내서 3개 작성하였습니다
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012 회원
CLEM-BENSON-S12S2G1
3 회원들
안내서 6개 작성하였습니다
Because of the difference between two people in the morning but I'm going&@6899!12;;....,
Rich Ridout - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,237
