주요 콘텐츠로 건너뛰기
Sirius Stiletto 2 Front Cover Replacement
필요한 것
  1. Sirius Stiletto 2 Front Cover Replacement, Battery: 1 단계, 이미지 1/1
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
  2. Sirius Stiletto 2 Front Cover Replacement: 2 단계, 이미지 1/2 Sirius Stiletto 2 Front Cover Replacement: 2 단계, 이미지 2/2
    • Pinch the battery from both sides and lift the battery to remove it.
  3. Sirius Stiletto 2 Front Cover Replacement, Front Cover: 3 단계, 이미지 1/1
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
  4. Sirius Stiletto 2 Front Cover Replacement: 4 단계, 이미지 1/2 Sirius Stiletto 2 Front Cover Replacement: 4 단계, 이미지 2/2
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
결론
Benjamin Her
회원 가입일: 01/21/15
555 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-6, Brown Winter 2015 USF Tampa, Team 6-6, Brown Winter 2015 회원
USFT-BROWN-W15S6G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 286
