주요 콘텐츠로 건너뛰기
Sirius Stiletto 2 LCD Display Replacement
필요한 것
  1. Sirius Stiletto 2 LCD Display Replacement, Battery: 1 단계, 이미지 1/1
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
  2. Sirius Stiletto 2 LCD Display Replacement: 2 단계, 이미지 1/2 Sirius Stiletto 2 LCD Display Replacement: 2 단계, 이미지 2/2
    • Pinch the battery from both sides and lift the battery to remove it.
  3. Sirius Stiletto 2 LCD Display Replacement, Front Cover: 3 단계, 이미지 1/1
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
  4. Sirius Stiletto 2 LCD Display Replacement: 4 단계, 이미지 1/2 Sirius Stiletto 2 LCD Display Replacement: 4 단계, 이미지 2/2
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
  5. Sirius Stiletto 2 LCD Display Replacement, LCD Display: 5 단계, 이미지 1/1
    • Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
  6. Sirius Stiletto 2 LCD Display Replacement: 6 단계, 이미지 1/2 Sirius Stiletto 2 LCD Display Replacement: 6 단계, 이미지 2/2
    • Carefully grip the screen and pull it away from the ribbon connector located on the motherboard.
  7. Sirius Stiletto 2 LCD Display Replacement: 7 단계, 이미지 1/1
    • LCD display (left).
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Benjamin Her
회원 가입일: 01/21/15
555 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-6, Brown Winter 2015 USF Tampa, Team 6-6, Brown Winter 2015 회원
USFT-BROWN-W15S6G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 408
