주요 콘텐츠로 건너뛰기
SiriusXM Onyx Plus Antennae/Powerport Replacement
필요한 것
  1. SiriusXM Onyx Plus Antennae/Powerport Replacement, Antennae/Powerport: 1 단계, 이미지 1/2 SiriusXM Onyx Plus Antennae/Powerport Replacement, Antennae/Powerport: 1 단계, 이미지 2/2
    • Remove the two 7.6mm Torx T6 screws from the back of the docking station.
  2. SiriusXM Onyx Plus Antennae/Powerport Replacement: 2 단계, 이미지 1/1
    • Pull the back casing off.
  3. SiriusXM Onyx Plus Antennae/Powerport Replacement: 3 단계, 이미지 1/1
    • Once apart, lift the docking station motherboard up from the two pins that are located on the interior of the front casing.
결론
Angel Rivera
회원 가입일: 01/25/18
532 평판
안내서 5개 작성하였습니다
USF Tampa, Team S7-G2, Passmore Spring 2018 USF Tampa, Team S7-G2, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 32
전체 시간: 1,787
