주요 콘텐츠로 건너뛰기
SiriusXM Onyx Plus Motherboard Replacement
필요한 것
  1. SiriusXM Onyx Plus Motherboard Replacement, Case: 1 단계, 이미지 1/1
    • Wedge a plastic opening tool in between the case.
  2. SiriusXM Onyx Plus Motherboard Replacement: 2 단계, 이미지 1/3 SiriusXM Onyx Plus Motherboard Replacement: 2 단계, 이미지 2/3 SiriusXM Onyx Plus Motherboard Replacement: 2 단계, 이미지 3/3
    • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
    • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
  3. SiriusXM Onyx Plus Motherboard Replacement: 3 단계, 이미지 1/1
    • Once unclipped, separate the back casing from the device.
  4. SiriusXM Onyx Plus Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 SiriusXM Onyx Plus Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Remove the three 5.4mm JIS #00 screws from the motherboard.
  5. SiriusXM Onyx Plus Motherboard Replacement: 5 단계, 이미지 1/1
    • Unlatch the two clips located at the top of the device that hold the motherboard in place.
  6. SiriusXM Onyx Plus Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift the motherboard up from the bottom.
  7. SiriusXM Onyx Plus Motherboard Replacement: 7 단계, 이미지 1/1
    • Lift the screen up, so you can see where it is attached to the motherboard.
  8. SiriusXM Onyx Plus Motherboard Replacement: 8 단계, 이미지 1/1
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  9. SiriusXM Onyx Plus Motherboard Replacement: 9 단계, 이미지 1/1
    • Carefully pull the ribbon out from the ZIF connector.
결론
Angel Rivera
회원 가입일: 01/25/18
532 평판
안내서 5개 작성하였습니다
USF Tampa, Team S7-G2, Passmore Spring 2018 USF Tampa, Team S7-G2, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 28
전체 시간: 1,793
