소개
If you are thinking of reusing your bearings for a new skateboard setup, it is advised that you use the guide in order to prolong the life of your bearings.
필요한 것
Protect your work area such as a desk with paper towels or newspaper.
Remove your bearings from your wheels, if they are not removed already. Please reference the Wheel Installation guide for information on how to properly remove bearings.
Carefully wipe the bearing with a lint-free cloth that is slightly oily. After this you can replace the protective shield by simply pressing it into place.
Repeat steps 8 - 7 for all other bearings. After you have completely relubricated all of your bearings, see the Wheel Installation guide to help you install your bearings into your wheels.
Cleaning and maintaining your skateboard bearings is crucial to their extended use. This process can be repeated as often as desired by the rider.
다른 2명이 해당 안내서를 완성하였습니다.
