소개
This manual will show you how to correctly remove wheels, change bearings, and install new wheels onto your skateboard.
You may reuse old bearings, or purchase new ones.
필요한 것
With a 13mm wrench, remove the axle nut located in the center of the wheel.
Set the axle nut aside, and remove the wheel.
Position the wheel at the end of the axle.
To remove the bearings, gently pry the wheel at a downward angle.
Perform this prying process on both sides of the wheel.
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
I am having stick like nut
Srijan Suryansh - 답글
