주요 콘텐츠로 건너뛰기
Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement
필요한 것
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Un-clip Battery: 1 단계, 이미지 1/1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: 2 단계, 이미지 1/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: 2 단계, 이미지 2/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: 2 단계, 이미지 3/3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sean
회원 가입일: 09/23/14
282 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-3, Blackwell Fall 2014 USF Tampa, Team 2-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S2G3
5 회원들
안내서 9개 작성하였습니다
댓글 5개
my battery is stuck in the drill any ideas
yonko99 - 답글
My battery is also stuck. I see no replies. What now?
Bobby Verdier - 답글
Thank you, it really was easy !!!!!
Betty - 답글
My battery is stuck too. I read on another forum to use a screwdriver and hammer.
I’m a girl, so don’t take my advice, but wondering if you could you spray it with WD-40 to loosen it up?
Amy Dionne - 답글
Have you been able to get it out? On mine the button was hard to get all the way down. I used both thumbs and was eventually able to get it down far enough to get it off. I bumped it on my leg to help loosen it. If you use a hammer I would suggest using a rubber mallet so you don’t damage the battery or the drill.
Once it’s off clean up the slides real good, spray some WD40 on them, then wipe off with a rag. That should help prevent it from getting stuck again. I would spray a little WD40 on the button and work it back and forth as well.
Hope this helps
Brian Harrod -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 67
전체 시간: 6,115
