주요 콘텐츠로 건너뛰기
Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement
필요한 것
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Un-clip Battery: 1 단계, 이미지 1/1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: 2 단계, 이미지 1/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: 2 단계, 이미지 2/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: 2 단계, 이미지 3/3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: 3 단계, 이미지 1/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: 3 단계, 이미지 2/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: 3 단계, 이미지 3/3
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
  4. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: 4 단계, 이미지 1/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: 4 단계, 이미지 2/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: 4 단계, 이미지 3/3
    • The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
  5. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the chuck sleeve: 5 단계, 이미지 1/2 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the chuck sleeve: 5 단계, 이미지 2/2
    • The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
결론
Jameson
회원 가입일: 09/23/14
258 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-3, Blackwell Fall 2014 USF Tampa, Team 2-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S2G3
5 회원들
안내서 9개 작성하였습니다
댓글 한 개
For my drill, the Torx screw had to be rotated *counter-clockwise to remove. I'm not sure if that was an error in step #5 or some drills are different.
Thank you for the location of those screws btw.
"Step 5 — Remove the chuck sleeve
and rotate it *clockwise to loosen and remove
the chuck sleeve."
Joe Bailey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 1,518
