주요 콘텐츠로 건너뛰기
Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement
필요한 것
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Un-clip Battery: 1 단계, 이미지 1/1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: 2 단계, 이미지 1/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: 2 단계, 이미지 2/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: 2 단계, 이미지 3/3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: 3 단계, 이미지 1/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: 3 단계, 이미지 2/3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: 3 단계, 이미지 3/3
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
결론
Sean
회원 가입일: 09/23/14
282 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-3, Blackwell Fall 2014 USF Tampa, Team 2-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S2G3
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 16
전체 시간: 434
