주요 콘텐츠로 건너뛰기
SkullCandy Hesh Auxiliary Cable Replacement
필요한 것
  1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: 1 단계, 이미지 1/1
    • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
  2. SkullCandy Hesh Auxiliary Cable Replacement: 2 단계, 이미지 1/1
    • Using wire cutters, cut the auxiliary cable at the determined damaged area.
    • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
  3. SkullCandy Hesh Auxiliary Cable Replacement: 3 단계, 이미지 1/2 SkullCandy Hesh Auxiliary Cable Replacement: 3 단계, 이미지 2/2
    • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
  4. SkullCandy Hesh Auxiliary Cable Replacement: 4 단계, 이미지 1/1
    • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
    • Twist together the same colored wires from the device cable and the new cable.
  5. SkullCandy Hesh Auxiliary Cable Replacement: 5 단계, 이미지 1/1
    • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
  6. SkullCandy Hesh Auxiliary Cable Replacement: 6 단계, 이미지 1/1
    • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
결론
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
Sarah Burk
회원 가입일: 01/15/15
247 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 17
전체 시간: 1,014
