주요 콘텐츠로 건너뛰기
SkullCandy Hesh Size Adjuster Replacement
필요한 것
  1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: 1 단계, 이미지 1/2 SkullCandy Hesh Size Adjuster Replacement, Determine the damage: 1 단계, 이미지 2/2
    • Locate the break in the device.
  2. SkullCandy Hesh Size Adjuster Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
  3. SkullCandy Hesh Size Adjuster Replacement: 3 단계, 이미지 1/1
    • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
  4. SkullCandy Hesh Size Adjuster Replacement: 4 단계, 이미지 1/2 SkullCandy Hesh Size Adjuster Replacement: 4 단계, 이미지 2/2
    • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
  5. SkullCandy Hesh Size Adjuster Replacement: 5 단계, 이미지 1/1
    • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
  6. SkullCandy Hesh Size Adjuster Replacement: 6 단계, 이미지 1/1
    • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
결론
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
회원 가입일: 01/15/15
247 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 25
전체 시간: 845
