주요 콘텐츠로 건너뛰기
Skullcandy Crusher Wireless Folding Hinge Replacement
필요한 것
  1. Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: 1 단계, 이미지 1/3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: 1 단계, 이미지 2/3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: 1 단계, 이미지 3/3
    • Extend and fold the hinge of the headphones you are trying to replace.
  2. Skullcandy Crusher Wireless Folding Hinge Replacement: 2 단계, 이미지 1/3 Skullcandy Crusher Wireless Folding Hinge Replacement: 2 단계, 이미지 2/3 Skullcandy Crusher Wireless Folding Hinge Replacement: 2 단계, 이미지 3/3
    • Remove two 14 mm Torx T6 screws on the underside of the headband.
  3. Skullcandy Crusher Wireless Folding Hinge Replacement: 3 단계, 이미지 1/3 Skullcandy Crusher Wireless Folding Hinge Replacement: 3 단계, 이미지 2/3 Skullcandy Crusher Wireless Folding Hinge Replacement: 3 단계, 이미지 3/3
    • Pry the speaker away from the headband with a slight force.
  4. Skullcandy Crusher Wireless Folding Hinge Replacement: 4 단계, 이미지 1/3 Skullcandy Crusher Wireless Folding Hinge Replacement: 4 단계, 이미지 2/3 Skullcandy Crusher Wireless Folding Hinge Replacement: 4 단계, 이미지 3/3
    • Remove two 5 mm Phillips #1 screws on the underside of the headband.
  5. Skullcandy Crusher Wireless Folding Hinge Replacement: 5 단계, 이미지 1/2 Skullcandy Crusher Wireless Folding Hinge Replacement: 5 단계, 이미지 2/2
    • Remove the top plastic part of the hinge.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Val
회원 가입일: 03/31/22
1,104 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22S1G33
1 회원
안내서 12개 작성하였습니다
댓글 7개
Hello. Any idea where can i buy the folding hinge from? thx!
Liviu - 답글
Hi, Like the explanation but can you tell me where to buy tge folding hinge?
Menno de Gier - 답글
I'm 3D printing these here https://www.ebay.co.uk/itm/364153346438
Stronger than original.
Eatfire - 답글
This is my alternative solution, albeit a temporary one. Sharing for people that end up here through search engines.
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
https://guide-images.cdn.ifixit.com/igi/...
Cus7od35 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 44
30일 전: 176
전체 시간: 9,116
